Condenser Testing - NCRS Discussion Boards
Condenser Testing
  • Gerald C.
    • June 30, 1987
    • 1309
    Condenser Testing
    I have a 63 roadster and want to replace the electrical condensers. I'd like to know how I go about testing the existing ones I have before buying any new ones.
    Jerry
  • Gary C.
    Administrator
    • October 1, 1982
    • 17916
    Re: Condenser Testing
    Jerry, here's how I do it. Gary....
    To test use an analog or digital volt ohm meter (VOM) set for ohms. First remove/disconnect the capacitor from the circuit. Second short the terminals with a screwdriver or capacitor lead to the case to be sure the capacitor is discharged. Check with the analog or digital VOM meter with red (+) VOM test lead to the capacitor lead wire and the black (-) negative test lead to the capacitor metal case. VOM should read open as capacitors have infinite resistance (they block and don't conduct). Then reverse the VOM leads to the capacitor contacts; black to capacitor lead, red to capacitor metal case, the needle should jump (capacitor kick) and return to infinite resistance if the cap is good.
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Gerald C.
      • June 30, 1987
      • 1309
      Gary,
      Is there any way to bench test these on a stand alone basis?
      Jerry
      • Gary C.
        Administrator
        • October 1, 1982
        • 17916
        Jerry, that is a bench test. Otherwise you'd need a capacitor tester, which most of us don't have. Gary....
        NCRS Texas Chapter
        • Gerald C.
          • June 30, 1987
          • 1309
          Gary,
          Thanks for the info. I'll see if an electrical shop around here has this equipment for the testing.
          Jerry
          • Mike B.
            • November 1, 2004
            • 389
            If you are near a Harbor Freight, go and buy the tester for $3 - $5. Or you can buy it at Sears or Home Depot for around $20.
            A Volt-Ohm tester is an indespensible and fundamental tool for basic troubleshooting. Once you learn even the basic functions you will wonder how you did without it.
