1972 MC Bail Sticker Question - NCRS Discussion Boards
  • Stan B.
    • March 11, 2008
    • 13
    I have a '72 without PB and I am trying to determine the correct bail sticker. According to the JM, the brake code was YA in '70 and '71 and in "later" '72 it was "HC." Am I to believe that "later" means late '72, or subsequent to '70 and '71? If I have to got with the HC sticker, does anyone out there no where I can find one? I can find the others, but not that one. Thanks.
  • Tom R.
    • June 30, 1993
    • 4102
    Re: 1972 MC Bail Sticker Question
    Stan, the bail tag characters reflects the broadcast code stamped into the machined boss area where the date code is stamped. Assuming you've got the original...it will be stamped there.
    Also, the tech guide mentions that "later 72" means after serial number 25,000 to 26,000 if that helps to sort out which is correct for your Corvette. Seems key to base it on your s/n.
    Having said all that and reading the manual, I interpret it to say that if you have an early 72 manual brake car, the code is ZC and if a later 72 (s/n 25,000 +) TG is stamped on the front line fitting surface with date code. but than the last paragraph on the next page seems to contradict what's written on page 84 stating tht HC is the code for late model 72s with manual brakes. I can't say this section is particularly well written.
    Stan Feliniski is the team leader...drop him a note to get it right.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
