Brake drums - NCRS Discussion Boards
Brake drums
  • B C.
    Infrequent User
    • September 30, 1987
    • 7
    Brake drums
    Hey there
    I'm in the process of redoing the brakes on my 62 and am replacing
    the front drums.
    The only drums available locally do not have the groove to hold the
    anti-chatter spring and they are less expensive.
    Is this spring really necessary or do I just assume the new drums do
    not require these?
    thanx
    BJ
  • Mike E.
    • February 28, 1975
    • 5138
    Re: Brake drums
    Those, as you probably know, are anti-squeak springs. You only need them a) if your brakes squeak, or b) if you have the car judged.
    Do make sure that the drums are decent quality, because in braking, cheaper is not necessarily better.
    • Roy B.
      • February 1, 1975
      • 7044
      Re: Brake drums
      At times you can find them on e-bay under chevy 48 up new or good used ones
      • Timothy B.
        • April 30, 1983
        • 5186
        Re: Brake drums
        How do the springs keep the drums from squeaking? I always thought out of round drums do this. My 63 had two springs on the front and none on the rear, I don't know if they were missing or used only on the front.
          Re: Brake drums
          Tim-
          The springs damp the harmonics developed in the drum that result in the "squeaking".
          • B C.
            Infrequent User
            • 7
            Re: Brake drums
            Thanx for the responses.
            Several old time mechanics in the area tell me they remember these springs
            rusting off in the 60's and nobody paid a lot of attention to replacing them.
            I worked in the trade then and do remember similar situations, I also
            remember changing these springs over to new drums (in the 60's).
            Many aftermarket drums did not have the groove for the spring but GM drums did.
            The drums I have from Car Quest do not have the groove but here is an
            interesting bit of info.
            The old drums had a discard spec of 11.060 but they had the groove.
            The new drums have a discard spec of 11.090 with no groove.
            One explanation is this extra thickness on the new drums may dampen the harmonics without a spring and along with the newer technology friction materials, squeaking may not occur.
            I'm going to use the Car Quest drums, I'll let you know how it goes.
            cheers
            BJ
