Will axles from a 69 Camaro with posi fit a 61 Corvette with posi? If not does anyone know a supplier that doesn't charge "restoration" prices for axles?
61 rear axles interchangeability
Re: 61 rear axles interchangeability
Here's axle length info for 59-62 Corvette:
L Axle Length 28 7/16 in., R Axle Length 29 15/16 in.
There was also a .1 inch doughnut spacer between the axle bearing and the inside of the axle housing. Hope this helps. Gary....
NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
Jerry-----
No way. The 57-62 Corvette uses different length axles for each side as Gary mentioned. 1969 Camaro uses the same length axle for each side and it's not the same as either of the Corvette axles. Beyond that, the Corvette axles are 17 splines; the Camaro axles are 28 or 30 splines, depending upon whether they are 10 bolt or 12 bolt rears.
You might try Tom's Differentials for axles.In Appreciation of John Hinckley- Top
Jerry,
i just measured my ( spare) axles.. '56-'62.........my car is a '58..
posi axle= LH-28 1/2"...RH= 30 1/8 "
non-posi= LH-28 3/4"...RH= 30 1/4 "
i don't think using the axle-set's interchangably will matter. ( posi or non-posi in the carrier)..
hope this help's..
john- Top
For some reason over the years 57-62 Chevrolet changes the lengths and bearing widths. Although the various 57-62 years are very close in lengths to each others there are differences. As well posi and non-posi axles lengths are different from each other. Gary....
NCRS Texas Chapter
55 to 62 Chevrolet passenger car axles will interchange with 56 to 62 Corvettes. The other GM makes from this vintage (Pontiac Buick etc) are too long. Rich- Top
