Ex122 - NCRS Discussion Boards
Ex122
  • Joseph T.
    • April 30, 1976
    • 2074
    Ex122
    EX122 on display at Fun Fest...
  • Kevin M.
    • November 1, 2000
    • 1271
    Re: Ex122
    How come you never see the hood open, I missed it at Flint open for just a minute.
    Kevin
    • Eric J.
      • March 1, 1980
      • 771
      Re: Ex122
      I think it still has the V8 in it...
      • Anthony S.
        • September 3, 2007
        • 108
        Re: Ex122
        A little more on EX 122
        There are two kinds of friends; the friend you call to bail you out of jail and the friend sitting next to you in the cell saying "Damn, that was great"!!!
        • Eric J.
          • March 1, 1980
          • 771
          Re: Ex122
          EX122 To Do List...
          Body Change... Check
          Frame Change ... Check
          Engine Change ... Check
          Transmission Change ... Check
          Destroy all removed parts ... Check
          Wait 40 years ... Check
          Restore to orignial condition .... Uh how do I do that?....
          Never mind just make it look like a 53 with different side moldings, but never open the hood.. Check
          I liked it better when it was red with a V8
          • Philip C.
            • December 1, 1984
            • 1117
            Re: Ex122
            ERIC AMEN to that!! Phil 8063
            • Kent K.
              • December 1, 1982
              • 1139
              Re: Ex122
              Next time someone sees EX122, please measure the fender scoops and take a photo of theleft one with tick-mark-stick beside it for length and width. I would like to compare it with the part Steve Koss bequethed to me that he cut out of the Motorama car (whatever the build number assigned to it).
              Thanks, Kent
              Kent
              NCM Founder - Member #718
              • Eric J.
                • March 1, 1980
                • 771
                Re: Ex122
                I propose that we name whatever award is the direct opposite of the 4 Star "Bowtie Award" The "EX122 Award". It has had more things changed then Micheal Jackson. Kerbeck does many things to promote the hobby, I just wish he would not pimp this as the Motorama Car.... That car is long gone. IMHO The Motorama 54 Hardtop that has been posted here has a lot more provenance and significance
                As far as the dimensions of the scoops, well they wern't there when it was red so my guess is it is whatever a 56-7 scoop measures.
                • Joseph T.
                  • April 30, 1976
                  • 2074
                  Re: Ex122 Fender Scoops
                  Thanks, Kent
                  Kent here are pictures of the left and right side scoops. I am not connected to this car in any way. I just took pictures of it at Funfest as it was readily available to all who were there. I have learned that if one wants to know the history behind a restored car...just talk to the guy that did the restoration ie: the 1954 F88 Olds. showcar. This EX122 car has been in the public eye for many years and I suspect whatever restoration has been done would be easily learned...by asking.
                  • Kent K.
                    • December 1, 1982
                    • 1139
                    Re: Ex122
                    The one that Steve Koss cut out of the Motorama car is about 5 1/2 inches long by 4 inches wide.
                    If I knew how to attach photos to a response, I have photos of this scoop, top and underneath.
                    Regards, Kent
                    Kent
                    • Joseph T.
                      • April 30, 1976
                      • 2074
                      Re: Ex122
                      Regards, Kent
                      My failing memory seems to be that there were at least two 1953 motorama cars..one for the USA and one for Canada with one being documented as a test burn vehicle. Could it be that Steve Koss cut a fender scoop out of the body that was used as a burn test body?
                      Plus I think recently published history commented that numerous test bodies were around styling at the time.
                      Loren and others have studied this much more closely.
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17971
                        Re: Ex122
                        Kent, to post pictures, select Post Reply, enter your text, scroll down and click onto Manage Attachments, then browse your computer to find the photos you want to upload. Photos max size are 95 kb. Gary....
                        NCRS Texas Chapter
                        https://www.ncrstexas.org/
                        • Kent K.
                          • December 1, 1982
                          • 1139
                          Re: Ex122
                          Joe,
                          I have asked on this board for photos of the Motorama presentations following the Waldorf. Steve indicated that he cut the left scoop out while another Tech Center Parts Fab (in the fiberglass program) worker cut the other scoop out at the direction of the lead designer (Bill Mitchell ?). While no one was looking, Steve shoved it inside his shirt and left with it at the end of the day. Anyway, photos of later Motorama shows will determine between which two the scoops were deleted. Scoops on EX122 appear to be the same size as '56-7 and are too big to represent the actual Motorama car(s).
                          Kent
                          Kent
                          • Eric J.
                            • March 1, 1980
                            • 771
                            Re: Ex122
                            The history of EX122 has been examened and reexamined at great length. . From my understanding Very little (if any) remains of the original Motorama car. See Spring 79 Restorer for a very good recap. Eric
                            • William L.
                              • December 1, 1988
                              • 944
                              Re: Ex122
                              Joe: This is from my Ed Teskey picture file. I dont know where or what year the picture was taken, but I think this car is a Prototype or a very early car?
                              "Lace"
                              Bill Lacy
                              1998 Indy Pacecar
