Removing C2 Shift Boot - NCRS Discussion Boards
  • Michael A.
    • March 1, 1996
    • 507
    I've got my interior removed, including seats, carpets, center console etc. I need to replace the shift boot. Before I do something stupid I want to check on the correct way to do this.
    My shift boot does not appear to be removable by stretching over the revers lock out t-bar handle. It appears that I have to remove the shifter from the linkage. I started to remove the pin at the base that runs in the same direction as the driveshaft but it does not want to come out easily. The first 1/4 inch movement is easy but then it gets stuck.
    Before I try to start pounding on it I thought I'd check on the forum to see if I'm doing something wrong.
    1. Is the one pin I'm working with the only thing holding the shift lever to the linkage?
    2. The exploded view of the chassis service manual shows another pin running perpindicular the driveshaft direction. However it does not appear to be going into the shift lever. Am I reading that right?
    It sure is fun to be working on the car again, even if it is 43 degrees in the garage!
    Thanks in advance for the help
    Mike Andresen
    Bloomington, IL
    Re: Removing C2 Shift Boot
    Michael -
    Unscrew the round shift knob, remove the spring under it, then pull up on the "T"-handle and remove it; boot will then pull right off the shaft.
      • 43219
      Michael -
      John and Michael-----
      Yup. And not only does that procedure apply to C2's, it's the same for most, if not all, other year Corvettes, too.
      • Noel K.
        • November 1, 2004
        • 84
        Michael,
        Get yourself a new kerosene heater for your garage. It's 20 degrees outside today and my two car garage interior temp is 62. Don't burn it when your not there to attend it.
        Cheap heat for the money - reasonably clean burning - especially if well maintained - and will keep your fingers from going numb from the cold !
        • Michael A.
          • March 1, 1996
          • 507
          John & Joe - You are both are at where I started. I started by removing the knob and spring but discovered that there is a metal band around the shifter shaft. It is about 1 inch wide and is loose on the shaft. However it does not slip up over the threaded top of the shaft. Frankly I was perplexed (or some other p-word). I've attached a picture to show it.
          The band does not appear to have a seam where it can spread and be separated. It looks like the only way to remove it is to cut it off. As you can see in the picture there is some "duct tape" at the base of the shaft so I don't know what has been done to rig this up. However I do believe it is the original shifter. Do either of you have any suggestions?
          Thanks for the help.
          Mike Andresen
          Bloomington, IL
          • Michael A.
            • March 1, 1996
            • 507
            Garage Heat
            Noel - I am envious of your warmth. I think I'll grunt it out for what is left of this winter but may break down and do the same next year. Thanks for the suggestion.
            Cheers
            Mike Andresen
            Bloomington, IL
              Originally posted by Michael Andresen (27410)
              The band does not appear to have a seam where it can spread and be separated. It looks like the only way to remove it is to cut it off. Do either of you have any suggestions?
              Cut the band - it wasn't there originally, nor was the duct tape.
                • 43219
                John-----
                .....nor was that sissy-looking boot. I'd do just about anything to get something like that out of a car I owned.
                • Michael A.
                  • March 1, 1996
                  • 507
                  Thanks John. I thought so but wanted some confirmation. This is all new to me.
                  Cheers
                  Mike Andresen
                  Bloomington, IL
                  • Michael A.
                    • March 1, 1996
                    • 507
                    John-----
                    Consider it gone Joe!
                    Thanks for the help
                    Cheers
                    Mike Andresen
                    Bloomington, IL
                    • Mike M.
                      • May 31, 1974
                      • 8382
                      the boot shown i n the picture isn't a c-2 shifter boot.mike
