58 Part interchange help - NCRS Discussion Boards
  • Bob E.
    • April 30, 1999
    • 13
    I just discovered my 739 short block is missing the rear main bearing cap. Can anyone tell me what years I can use, IF I can find one.
    • 43245
    Re: 58 Part interchange help
    Bob-----
    Any rear cap from a 1955-58 small block will work. The cap may be identified by the casting number 3704108 or 3743949. You might check with a local automotive machine shop. They often save caps from scrap blocks.
    • Bob E.
      • April 30, 1999
      • 13
      Thanks Joe, appreciate the help.
      • Mike M.
        • May 31, 1974
        • 8397
        i've got one i'll give ya. send me yer snail mail address and i'll get it out monday.mike
        • Gary C.
          Administrator
          • October 1, 1982
          • 17757
          Need to be careful as bearing caps were supposedly matched to a block. If it's apart might want to have machine shop check for line bore. If crank's in car, check with plastic guage to verify proper clearance values. Gary....
          NCRS Texas Chapter
          https://www.ncrstexas.org/
            • 43245
            Gary-----
            Absolutely. One can NEVER exchange or replace ANY bearing cap on any block without having a competent machine shop check the alignment of the main bearing bores. In almost all cases, an align hone or align bore will be necessary. In some instances, a particular previously used cap might not even be usable with a recipient block. SERVICE main bearing caps, when they were available for this application, were supplied in "unfinished" form so that there was enough "meat" available to fit them to any block. Used caps have already been fitted to their original block and may not have enough "meat" available to be fitted to another block.
            • Mike M.
              • May 31, 1974
              • 8397
              Gary-----
              joe is right on. even if there isn't enough meat on a donor cap off a donor block, the donor cap can be cast welded then fitted to the recipient block. most good machine shops can handle the necessary machining to interchange caps.mike
