I thought I would share this with you. My car does have the tank sticker and protecto plate. It also come factory equipped with pb and ac (C60) (NO power steering). What are your thoughts on the pad stamp?
C2 1967 engine pad
Re: C@ 1967 engine pad
Jimmy,
I had a 1967 Coupe with 327/350 HP ,A/C, Power steering and Brakes with the same "T" stamped separately on the pad. I know mine was original and it looks exactly like yours. Apparently they did not produce many cars with those options.
- Top
Re: C2 1967 engine pad
To me, it looks like a very weatherbeaten pad. Much rust and pitting. Hard to distinguish broach from all of that rust and pitting. Almost looks like the engine was left exposed to the weather for many years, without the benefit of a grease/grime/dirt hat. The "T" can well be fine, but I need to see the broach marks first.
Suggest cleaning the pad better, and then sending a hi-res photo for our perusal.
Joe- Top
The pad's Letters look fine until you get to the "T". It looks like an overstike. It obviously wasn't included in the gang-holder on the 1st strike. Look at how faint the "H" is. It's possible the "T" was even more faint the first time around and that the past owner or the factory guy just had to restamp it. The pad "surface" is gone and would recieve a full deduction for lack of broach marks. Regards, Bob- Top
"What came first, the chicken or the egg?"The pad's Letters look fine until you get to the "T". It looks like an overstike. It obviously wasn't included in the gang-holder on the 1st strike. Look at how faint the "H" is. It's possible the "T" was even more faint the first time around and that the past owner or the factory guy just had to restamp it. The pad "surface" is gone and would recieve a full deduction for lack of broach marks. Regards, Bob
That's why I like to ser REAL (not belt sander) broach marks FIRST.
I cannot see broach marks on that pad........it's just too "beat-up". Without cleanup and better photo, it's useless. Might as well be painted.
The numbers........
Well, the "T" was a restrike.
I can't see evidence of another letter below the "T". So I'll bite, that it was just a faded original stamp that was "restruck".
I still need to see the broach marks.
Joe- Top
That looks real to me!!!!
REAL, subtle broach marks are visible.
Not the exaggerated kind created by forgers!
If somebody went to the trouble to restamp, then I would think that they would have included the alphanumeric date/suffix string.
Joe
PS: Upside-down characters were done quite often! Most of the time, those guys loading the stamp gangs were three-sheets-to-the-wind.- Top
Still stirring... here is one a few hundred away.Attached Files- Top
