72 T3 headlights - NCRS Discussion Boards
72 T3 headlights
  • Joe R.
    Infrequent User
    • July 15, 2007
    • 22
    72 T3 headlights
    I am looking for a full set of 72 style T3 headlights. Does anyone have a source for these?
  • Kevin M.
    • November 1, 2000
    • 1271
    Re: 72 T3 headlights
    Original will be hard to find the repops judge well.
    • James T.
      • May 31, 2006
      • 47
      I searched last year this time and no new bulbs were being produced. The explanation ranged from not enough demand to licensing problems. I found a working set on Friday of Corvettes at Carlisle. It was the only set I saw in three days. Get there early and know exactly what they look like. Good luck. Jim
      • Harmon C.
        • August 31, 1994
        • 3228
        Originally posted by Kevin Muldoon (35046)
        They don't make 72 style T-3's unless it is a new product and the other styles would not judge that well. You should be able to find some high beams used but the high lows are had to find.
        Lyle
        • William C.
          • May 31, 1975
          • 6037
          Don't forget all the other '72 GM cars that used those same bulbs in your search.
          Bill Clupper #618
          • Rob C.
            • August 31, 2004
            • 144
            They do show up on e-bay from time to time.
            They are expensive.
            Rob
              • 3415
              I believe that too often used originals burn out when turned on for the first time. I think it has something to do with the seal leaking. Perhaps someone who knows more can chime in. My originals still work but one has gotten foggy in side; sorta like my brain.
              • Bill C.
                • July 15, 2007
                • 904
                Joe -
                I think I have a complete set of LOW and HIGH beams.
                I bought from ebay a year or so back as a backup set for my car.
                I will check them on MOnday and be sure they are working okay.
                From what I remember, all four are clear and in REALLY excellent shape.
                Bill
                • Harmon C.
                  • August 31, 1994
                  • 3228
                  I have had many NOS bulbs burn out when tested on a full charged battery. I was told to use lower power and bring it up slow but never tried it as it was too late. Most agree that if the seal is broken they smoke and burn. Some have tried to seal the conection with PVC. Good luck with the test.
                  Lyle
                  Lyle
                  • Gary S.
                    • July 31, 1992
                    • 1632
                    Extremely rare! If you do find a set be prepared to pay through the nose since these were one year only headlights. Keep an eye on The Driveline as well as Hemmings Motor News.
                    You might want to look at repros which, I believe, will earn a mild deduction for the DOT feature as well as the icon on the lens.
                    Gary
                    • Kevin G.
                      • February 1, 2005
                      • 1076
                      Here is a hand out from 04 from a vendor at Carlisle I believe. Ignore the prices I'm sure they are not the same today.
