C3 Carpet overlap with firewall insulator - NCRS Discussion Boards
  • Richard U.
    Infrequent User
    • July 31, 1990
    • 2
    Does the top edge of the front carpet overlap the firewall insulator or is it fitted underneath the bottom edge of the firewall insulator? Do the rubber fastners retain both the carpet and the insulator or just the insulator?
    Thanks for your help! Richard Udd
  • Anthony M.
    • September 30, 2001
    • 58
    Re: C3 Carpet overlap with firewall insulator
    I fitted the carpet under the plastic insulator and then used the rubber plugs to hold the insulator inn place. I am not sure it is correct but it seemed like the logical way to put it together. I could not find a carpet reference in the AIM.
    • Harmon C.
      • August 31, 1994
      • 3228
      The carpet is fitted under the front lip. The plugs go through what ever is behind it in that location.
      Lyle
      Lyle
      • James T.
        • May 31, 2006
        • 47
        In a June '72 car, the carpet goes over the rubber insulator. The insulator is cut out where the plugs fasten. Top edge of carpet is unfinished. Jim
        • Harmon C.
          • August 31, 1994
          • 3228
          I'm not sure what year he is working on as my information was for a 73.
          Lyle
          Lyle
          • Richard U.
            Infrequent User
            • July 31, 1990
            • 2
            Sorry, should have reported that this is for a '69.
