What is the correct position of the step plate p.n. 3727549?
The A.I.M. shows the plate positioned at the front of the sill, although the drawing is not very definative. It also shows the step plate under the sill plate which makes sense(I think).
Pictures I have found show it as in the A.I.M. and up to 1/4 inch back from the front edge.
The JM does confirm the presence of the plate in general, not good enough to locate the plate.
Any help will be appreciated.
There is light at the end of the restoration tunnel, finally.
