I'm in the process of restoring a 61 Big Brake car. It has the original 5.5 inch wheels. I'm getting conflicting information on whether or not these wheels are to be used with an inner tube. As I understand it these rims do not have a bead ridge and the rivets may leak. Any expiriece with this problem? I don't have a problem using a tube, I'll probablly be using a period appearing racing bias tire on the rims. My tire installer says they have the larger valve stem holes so they are meant for tubes??    Jerry
					1961 5.5 inch wheels
Re: 1961 5.5 inch wheels
Jerry..Can you post a picture of the finned brake drums?I'm in the process of restoring a 61 Big Brake car. It has the original 5.5 inch wheels. I'm getting conflicting information on whether or not these wheels are to be used with an inner tube. As I understand it these rims do not have a bead ridge and the rivets may leak. Any expiriece with this problem? I don't have a problem using a tube, I'll probablly be using a period appearing racing bias tire on the rims. My tire installer says they have the larger valve stem holes so they are meant for tubes?? Jerry
Joe- Top
You could also brush epoxy paint over the rivets inside of the wheels. Used to do this on real magnesium wheels. Cured all leaking mags.Dick Whittington- Top
Agree w/tc...
Only as a precaution, (after bead blasting) I use either RTV or JB Weld Quick to prevent any possible leaks. Always have used tubeless tires. With an experience level of 23 wide wheels, not a leaker yet.
 Best, Dennis
						- Top
