C1 (1959 vs. 1960) Timing Cover Screws - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2143
    Members:
    Paragon lists a slotted screw kit for the 283 timing cover and indicates "1955-1959", (Kit number there is 4904K-10.) They also sell "L" head bolts and indicate "1956-1982". (Kit number 7605K.)
    I have seen the slotted ones on a 1960 engine, probably sourced from Paragon. Why would someone restore a 1960 engine with the slotted screws? The '60 I'm looking at was made in May, so it's not "early". (The owner believes he should have the slots.)
    My dealer replacement 1960 block had bolts, but it's been apart more than one time.
    THANKS!
    TD
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 (1959 vs. 1960) Timing Cover Screws
    I could be wrong but the water pumps C1's having the flat back plate using slot head screws also used them for the timing cover???? smarter people then me know!!
    • Mark C.
      • March 28, 2007
      • 21
      The late 59 I am doing now has the slotted screws Ser.# 108922. July 59 car.
      • Dave S.
        Infrequent User
        • April 30, 2005
        • 19
        Yes, my experience is that the timing cover and water pump plate screws are the same for 1959. I had an original engine and compared the slotted screws.
        Dave Sly
        515-450-2335
        davesly@iastate.edu
        • Tom D.
          • 2143
          C1 Thanks, but how about 1960 Timing Cover Screws?
          Tom Dingman
          Michigan Chapter
          Tom Dingman
