Mid '54 vs Late '55 body differences - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    I am aware of the '55 adjusted psgr inner fender as a difference; what else is there? I would appreciate as much detail as possible - I'm chasing a car's history. Thanks.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Mid '54 vs Late '55 body differences
    Fuel pump frame area
    engine mounts location holes
    left side dash area one hole (for light switch)
    trans tunnel forward holes and under guard plate
    steering box spacer & arm
    Radiator shroud holes in front frame & support holes
    drive shaft
    hood
    Fire wall holes
    I know I'm missing more but?
    • Michael H.
      • December 1, 2004
      • 118
      Roy has provided a good list, as usual. In addition to the obvious engine and radiator differences, I'd add that (1) there are holes in the '55 front fender for attachment of the "V" in the "Chevrolet" script, (2) the hole in the underbody for the ground wire for the radio (underneath the passenger door) on a '55 apparently consists of a slit for the wire, versus a hole with a small cover, (3) the '55 dash-mounted rearview mirror has a screw knob, (4) a late '55 might have holes on the drivers side fender well for attachment of the washer bag, versus the bottle. Mike
