C1 Wiring harness (Under Dash) - NCRS Discussion Boards
  • Ken K.
    • May 31, 1999
    • 235
    I removed the wiring harness from my 1959. (clean, repair, and rewrap)
    I'm in the process of re-installing it. I have a question on the routing or location on where the wiring harness should go. I mounted the fuse box (two screws) to the firewall. I ran the engine compartment wires through the firewall. The area that I need help with is the wires that then go to the cluster and other dash items. There is one clip mounted on the side kick panle area. How should the wiring harness be mounted in that area? Can someone please take a good photo of that corner area by the clip and show how the harness is routed and makes its way up to the other 6 clips mounted under the windshield?
    Thanks Ken
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12867
    Re: C1 Wiring harness (Under Dash)
    Check the AIM, it is pretty good explaining the routing of the dash wiring...
    regards,
    Rob.
    Rob.
    NCRS Software Developer
    • Dave S.
      Infrequent User
      • April 30, 2005
      • 19
      1959 (#7110) 250HP FI car.
      Dave Sly
      515-450-2335
      davesly@iastate.edu
      • Dave S.
        Infrequent User
        • April 30, 2005
        • 19
        More pics (1959 #7110)
        Dave Sly
        515-450-2335
        davesly@iastate.edu
