What years are pipes 3822581 and 3822582 correct for? - NCRS Discussion Boards
  • Brad M.
    • July 31, 2005
    • 262
    I was wondering what the correct applications are for 2 inch small block pipes part numbers 3822581 and 3822582.
    • 43247
    Re: What years are pipes 3822581 and 3822582 correct for?
    Brad-----
    GM #3822581 and 3822582 are the left and right front exhaust pipes for 1963-only Corvettes with small block and all 250 hp or 300 hp with Powerglide.
    • Brad M.
      • July 31, 2005
      • 262
      Thanks Joe
      • Dick W.
        • 10483
        Brad, Gardners Exhaust may have some interest in those pipes to make paterns.
        Dick Whittington
        • Brad M.
          • July 31, 2005
          • 262
          Dick,
          Do you know if that system is one that Gardner's is not yet making? (answer to that may be on their site if you do not know - I can check).
          It seems that they are maybe more interested in factory installed systems rather than service replacement ones, but I am open to giving them up if they need them.
            • 43247
            Brad-----
            The forward pipes you described should be the same, PRODUCTION or SERVICE. Of course, if they are much later SERVICE pieces, there may be some minor differences from PRODUCTION and original SERVICE. The rear pipes and mufflers are different for PRODUCTION and SERVICE (except N-11). However, the "core" configuration is the same.
              • 15616
              Brad,
              You might want to communicate with Gardners. If they have an interest in them, I doubt you would have to give them up permanently. Might be a year or so, depending on where they are with their construction plans -- a conversation with them would clear that up. There might be a "reward" for you depending on how bad they want/need the examples.
              I know they are on the hunt for 2-inch 4-speed systems for 1969s, but I am not sure what their mid-year plans are.
              • Dick W.
                • 10483
                They are making the '65-'67 systems but not the '63-'64.
                Dick Whittington
                • Brad M.
                  • July 31, 2005
                  • 262
                  Thanks, I will call them.
