did the lt1's have the t60 heavy duty battery like the ls5? i know they had the 61 amp alternator but dont know about the battery.
70 LT-1 T60 hd battery
Re: 70 LT-1 T60 hd battery
Edit: My mistake...you're asking if it was standard equipment on the LT1. We'll have to wait for an LT1 expert.- Top
KEN65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
- Top
After all these decades, I'm certain it's not the one that came in it. If it's an R89W, it's either a repro, or it's an NOS dry charge battery that someone paid an arm and a leg to own.- Top
TERRY M. should be in on this.I let him use my battery when he had his LT-1 judged back in the day.
Since Terry has an early car, your original configuration battery would be perfect for his car, heavy duty or not, according to the TIM&JG. The real question in my mind is whether your battery is the ORIGINAL battery installed in St. Louis...if it is, then it's a miracle battery in my opinion.
This is really interesting to me...maybe it IS a miracle battery. You would think that later service replacements would supercede the R79 with the R89 that was used later in 70 model year production. Edit: Hmmm...maybe not if the terminals were different. Maybe Terry can explain exactly what you have in your car.Last edited by Chuck S.; March 4, 2008, 04:22 PM.- Top
If it WAS standard equipment for the LT1 as the OP originally asked, No, you would not see it itemized on the tank and window stickers.Last edited by Chuck S.; March 4, 2008, 05:40 PM.- Top
I'm pretty sure Terry will have something to add. Your battery wouldn't have to be a heavy duty battery, unless it is an R79W. I presume the standard battery was an R79S, using the same nomenclature as the later R89?
KEN
PS this battery died along time ago. The thing was dead when I loaned it to Terry. Sorry I mislead youLast edited by Kenneth B.; March 4, 2008, 05:43 PM.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
If I remember correctly, there was a terminal thread size change in the the later R89 that would make the two batteries (R79/R89) not interchangeable (cable ends wouldn't fit)...if that is the case, Delco would have had to maintain replacement battery supply for both R79 and R89 until the original configurations of both batteries were discontinued.Last edited by Chuck S.; March 4, 2008, 05:56 PM.- Top
Ken, my point in the last paragraph was that your battery was likely a replacement by the original owner during the time when the R79 batteries were still available from Delco. It's still a remarkable run even for a replacement battery.
