C2 Rear Leaf Spring - NCRS Discussion Boards
C2 Rear Leaf Spring
  • William B.
    • June 30, 2004
    • 26
    C2 Rear Leaf Spring
    Gentlemen,
    Could anyone tell me the best place to purchase a reporduction rear leaf spring for a 66 convt. I've tried Eatin and their spring was too long. The washers that are underneath the rubber cushions on each end make solid contact with the steel wheels (both). A friend of mine who tried Eaton also and ran into the same issue.
    Any help would be appreciated.
    Ken Bryant #42259
  • Donald T.
    • September 30, 2002
    • 1319
    Re: C2 Rear Leaf Spring
    William,
    Eaton does make the closest reproduction spring, as it has the curled ends. I recently installed one on my 65 and had no problems with the length. You may want to contact Eaton and see if they sent you the correct application.
    • Donald T.
      • 1319
      Here's a pic of the Eaton spring with the curled ends. The length was identical to the original. It's not an exact reproduction, but very close. The leaves have to be taken apart and repainted the correct gray color with no overspray on the liners. The cup pictured is the correct thinner version which is now available from Long Island Corvette. I think this is as close as you will get with a new spring.
      • William B.
        • June 30, 2004
        • 26
        Originally posted by William Bryant (42259)
        Gentlemen,
        Ken Bryant #42259
        Thanks Don,
        Picture looks like mine. When measuring along the curve, the longest leaf is 48 3/4 inches - end to end. I know this is not an eye-to eye measuement, but it's all I have at this point. Additionally, the connector bolts protrude significantly outwards at the point of entering the eye of the spring. Actually, they bind as they enter the eye.
        Thanks again
        Ken
        • Jim S.
          • March 1, 1986
          • 1408
          testing 1 2 3
          • Donald T.
            • 1319
            Ken,
            I measured my Eaton spring and an original and they were approximately 48 3/4". I would take a look at your trailing arms. Are they the stock configuration?
            • Wayne M.
              • March 1, 1980
              • 6414
              Originally posted by Donald Terry (38740)
              Ken,
              William -- I get 48_7/8" end-to-end on a stock '65 factory spring lower leaf; like Donald and Ken. Also, from the center of the bolt hole to the end is 1_3/16".
              What wheels do you have ? too much internal off-set could be the culprit if not stock.
              • Michael H.
                • January 29, 2008
                • 7477
                Agree. The original print shows a dimension of 48.60", or roughly 48 5/8" end to end, measured along the surface. Often, the actual measured length is slightly longer.
                The dim between the C/L's of the hole at the end is shown as 46.36", or about 46 3/8".
                • Jim D.
                  • December 1, 1994
                  • 82
                  Test post...were the springs painted the same gray as the shocks?
                    • 43258
                    Thanks Don,
                    Thanks again
                    Ken
                    Ken-----
                    When you say the bolts "bind" are you talking about the condition when the car is lifted up off the suspension, the spring highly arched, and the wheels are "hanging"? If so, the bolts will always "bind" under these conditions. When the suspension is on the ground and normalized things will "correct themselves".
                    • William B.
                      • June 30, 2004
                      • 26
                      Joe & et. al.
                      Thanks for the replys. Yes, the car is off the ground and the wheels are hanging. I was concerned about the closeness of the spring ends to the wheels and what appears to be an excessive amount of outward angle of the connecting bolts as they enter the spring eyes.
                      I'll put her on the ground and do a little rolling and see how it looks.
                      Thanks again,
                      Ken
                      • Chuck S.
                        • April 1, 1992
                        • 4668
                        No, not the same gray.
                        • Harry S.
                          • July 31, 2002
                          • 5332
                          Ken, take a look at:
