Shocks and Judging Points ... - NCRS Discussion Boards
  • Bill C.
    • July 15, 2007
    • 904
    Hey All ....
    Easy question (I hope) ....
    My car is a 1972 454 A/C car ....
    If I put a full set of pliacell shocks (with correct dates) but they are F-41 shocks - will I loose all points from both categories or 1/2 points ???
    My original front shocks are finally wore out - bounce too many times when tested.
    I want to help the handling characteristics of the car, thought F-41 shocks would do that. The car is a 454 A/C car, sloppy handling is an understatement.
    Bill
  • Bernard S.
    • June 30, 1992
    • 56
    Re: Shocks and Judging Points ...
    Bill: I have 72 454 AC convert. Drove it to Nashville and back for the 50th (2400 miles). After wards replaced shock with the GM std type- what a difference. You might not need F-41
    • Bill C.
      • July 15, 2007
      • 904
      I saw a set of dated (early 72) F-41 on ebay - thought they would work nicely on the car.
      I would be fine to put a standard set on - just can't seem to find any ...
      I was wondering how badly I would be penalized when I take the car for flight judging again?
      Bill
      • William C.
        • May 31, 1975
        • 6037
        Chassis judging of front shocks is somewhat limited by accessability to the area where the delco remy and part numbers are applied. If the Shocks are similar in appearance to the originals, and painted correctly, it would come down to the accessability of the stamped logo, which I believe is at the bottom of the spring pocket. IF SEEN it would create a deduction, if it can be seen.
        Bill Clupper #618
        • Dick W.
          • 10483
          No documented '72 cars with F-41. So why spend the bucks to buy dated F-41 shocks? Minimal deduction for correctly painted and decaled Pliacell shocks.
          For a driver I highly recommend Bilstein shocks. A world of difference between conventional shocks and them. You will not realize that you are in the same car.
          Dick Whittington
            • 15630
            I kind of think the diameter of the F-41s would be a give away on the judging field; but on a bright, sunny day with long field grass, and eight cars to judge it might not be noticed.
            There used to be some Delco shocks that when painted the proper gray color passed for the most part on the front of C3s, but I remember a couple of posts that those were discontinued a couple of years ago just before Delco got out of the shock making business. There still might be something close enough if paper/foil labels were removed and the proper blue/grey paint was applied. Front shocks are real hard to see -- rears are far easier.
            • Bill C.
              • July 15, 2007
              • 904
              THANK YOU !!!
              Great info - I think the best approach is to look for standard pliacell shocks and paint/label them correctly.
              Bill
              • Rob M.
                • June 30, 1999
                • 171
                The rears are easy to spot without the upper tubular shield. I would think that you would get full deduct on originality and condition too.
                My Project Pictures
                http://temp.corvetteforum.net/classics/l78vetteman/
                • Mike G.
                  • July 31, 2002
                  • 709
                  you will be better off with the new ac shocks painted the correct color unless your car is an f41 car then keep what you have.
