Tri Carb Mounting - NCRS Discussion Boards
Tri Carb Mounting
  • Lynn S.
    • November 1, 2004
    • 99
    Tri Carb Mounting
    Tri carb system is for 69 L89 car. Alum manifold is clean and all three carbs replated/built. The center carb needed a new base plate as the original had one corner broken. Front and rear carbs set flat on manifold but the center carb seems to have a little wobble corner to corner. I do not want to tighten it down and break the base plate. Can I use 2-3 gaskets? Would you put any sealer between the carb, gasket, manifold. Thanks
  • Kevin M.
    • November 1, 2000
    • 1271
    Re: Tri Carb Mounting
    Both of those fixes are going to cause problems, better get to the bottom of the wobble.
    Kevin
