Correct finish for 4 center bolts for rear spring? - NCRS Discussion Boards
  • Brad M.
    • July 31, 2005
    • 262
    What is the correct finish for the 4 center bolts that hold the rear spring (and the related plate) up to the rear end for a 71?
    • 3418
    Re: Correct finish for 4 center bolts for rear spring?
    I believe the 4 bolts were Black Oxide or a similar finish on my 71.
      • 11692
      Same here.
      Dull, flat black if I recall from ones I've seen. Not at home right now to check my NOS ones.
      Patrick
      • Brad M.
        • July 31, 2005
        • 262
        Thanks guys. I thought that was the case but I was not sure. I was not fiding any evidence of zinc.
        • Chuck S.
          • April 1, 1992
          • 4668
          Same here.
          Patrick
          My notes show them as black phosphate.
          Give your NOS bolts the "sunlight test" and confirm, Patrick...I may have been inexperienced enough to see black phosphate in every fastener when I wrote those notes.
            • 11692
            This is Michigan. In early March.
            Give me a couple of months.
            Patrick
            • Chuck S.
              • April 1, 1992
              • 4668
              Patrick
              Oh...Uh...Sorry, Patrick I wasn't thinking.
              With my plum tree in full bloom, I forget about the weaker sun at the higher latitudes....
                • 3418
                The condition on mine was such that I thought "black oxide", but it certainly could have been phosphate as Chuck suggests. There's not much of that bolt that's not out in the elements. Maryland was still using a combination of salt and sand on the roads back then. The dog legs looked like they had been sandblasted every spring.
                  • 43273
                  Alan-----
                  The original bolts were black phosphate-finished. The "black" varies from almost black to a medium gray on most black phosphate-finished parts. Black oxide is a completely different finish----much "blacker" and smoother. It was never used for these bolts.
