67 window crank knob - NCRS Discussion Boards
+ More Options
Posts
  • Justin N.
    • February 1, 2004
    • 318
    Dear members,
    Kinda bummed, just got my piece from eBay and the knob is painted instead of correct color rubber knob!!! I guess the pictures didn't do it justice or I should've asked more questions before bidding!
    Anyhow, does anyone make correct rubber, knobs for the handles? I see them in the catalogs. My crank handle say "5719477" on the back and the bottom of the knob has "S11B". The knob seems to be correctly peened onto the handle with a rivet. The rubber knob has three lines or "steps" on the side and many circles on the top, facing the passenger.
    Thanks!
    Justin #41362
  • Kevin M.
    • November 1, 2000
    • 1271
    Re: 67 window crank knob
    Original knobs have a step down instead of taper like service replacements that is the most important feature and only found on factory knobs. I'd also ask the seller for your money back you should not have to asked is it painted BS.
    Kevin
    lastpostontheoldb
    • Kevin M.
      • November 1, 2000
      • 1271
      Kevin
      lastpostontheoldb
      • Joe R.
        • March 1, 2002
        • 1356
        Hi Justin:
        What color are you looking for? There is a pretty good reproduction available for the handle with a black knob, but only black.
        • Joe R.
          • March 1, 2002
          • 1356
          Hi Justin:
          • Kevin M.
            • November 1, 2000
            • 1271
            The repops have the right taper? I'll wait till the new board to post the picture of the correct knob.
            Kevin
            • Kevin M.
              • November 1, 2000
              • 1271
              Kevin
              • William L.
                • December 1, 1988
                • 944
                Re: 67 window crank ****
                Justin
                What color are you looking for I may be able to help you?
                Bill
                Bill Lacy
                1998 Indy Pacecar
                • Michael W.
                  • April 1, 1997
                  • 4290
                  Let me guess, there's a naughty word filter, and it's blocked the word k.n.o.b.?
                    • 11698
                    Shall we try it?
                    So far we have k-n-o-b or knob
                    and
                    s-p-a-c-e or ****e.
                    will they get blocked?
                      • 11698
                      Shall we try it?
                      and
                      s-p-a-c-e or ****e.
                      Nope.
                      Apparently you can still have knobs. Just no spa(y)ces.
                      I think that word block list needs editing...
                      • Joe R.
                        • March 1, 2002
                        • 1356
                        [quote=Kevin Muldoon;280156]The repops have the right taper? I'll wait till the new board to post the picture of the correct knob.
                        Hi Kevin:
                        Some time ago I found a source for a repro that I thought looked pretty good, but it was only available with a black knob. I can dig one out and try taking a photo if you are interested.
                        • Kevin M.
                          • November 1, 2000
                          • 1271
                          Justin,
                          Sure but I found my picture, you can see the taper on the inside of the knob, don't know of any reproduction that has it. Check your picture if it's the same you've found a correct source.
                          Kevin
                          • Joe R.
                            • March 1, 2002
                            • 1356
                            Hi Kevin:
                            I'm having some difficulty attaching photos, but here are the photobucket URLs for three photos that compare an original 67 window crank with a $12 reproduction from rickscamaros.com, part number IN-118:
                            http://i21.photobucket.com/albums/b281/jpr3/Windowcrankcomparisonfront.jpg
                            http://i21.photobucket.com/albums/b281/jpr3/Windowcrankcomparisonback.jpg
                            http://i21.photobucket.com/albums/b281/jpr3/Windowcrankcomparisonside.jpg
                            I think that the knob and the front of the repro handle are very good, although there are some differences on the back side. I think a judge would need to use a mirror to detect this repro.
