Correct # of 63 300 HP air filter? - NCRS Discussion Boards
  • Stan E.
    • April 30, 1991
    • 383
    Can someone tell me the correct # for a 63 300 HP AC air filter? Thanks for your help!
  • Harry Sadlock
    Re: Correct # of 63 300 HP air filter?
    A165C.
    • Harry Sadlock
      A165C.
      • Stan E.
        • April 30, 1991
        • 383
        ReThanks, Harry *NM*
        • Stan E.
          • April 30, 1991
          • 383
          • Harry S.
            • July 31, 2002
            • 5346
            Welcome, just a reply to test the new S/W.
            Harry
            • Harry S.
              • July 31, 2002
              • 5346
              Stan, I should add that the filter is two sections. 1) a metal inner screen/ring and 2) a foam cover that goes over the ring. The foam is to be oiled for use.
              The original foam cover has the number embossed on the side, current reproductions do not have the A165C on them. As I recall GM stopped making the foam in the late 60's and went to a paper replacement. I think that is an A353C.
