Vibration during acceleration - NCRS Discussion Boards
  • Timothy B.
    • January 1, 2004
    • 438
    Hey guys, I'm looking for some advice on what the probable causes might be for a vibration I feel I have in my 1967 small block convertible with 4 sp.
    Long story short: I have a light vibration that is only noticeable during hard acceleration, seems to be felt in the seat. I can't seem to notice it when cruising at any speed - only during harder acceleration generally in 2nd and 3rd gears. History: I have had the tranny out three times in the last couple of years all associated with installing a new clutch. The first time I installed a new LUK kit, had the flywheel surfaced and balanced as an assembly. Didn't have vibrations but clutch engagement was poor and chattered. Pulled the trans a second time, had flywheel resurfaced (trying to get the runout down) and assembly balanced again (same shop as the first time). Clutch still chattered. I pulled the trans a third time (uugh!!!), gave up on the LUK kit and installed the correct GM kit, and had the assy balanced at a different shop. Finally the new shop got the run-out nice and low, and told me they were able to balance the assy nicely. Turns out the LUK kit was defective. Now, the GM clutch feels fine and has no chatter (which is great), but I have the light vibration during acceleration described above.
    Obviously, I quite tired of pulling the trans on my car. I have tried relocating the driveshaft on the rear hub with no improvement. I had also tried rotating the front of the shaft 180 deg on the output shaft. No change. The vibration is not felt in the car with the clutch held depressed, so I believe I can rule out suspension, tires, and wheels. No vib felt in shifter at all.
    Are there any suggestions out there as to how to help isolate the problem? Before I pull the trans again and try to get the clutch and flywheel balanced again by possibly a third shop, maybe there could be another cause? Why would it be noticeably only during acceleration?
  • Verle R.
    • March 1, 1989
    • 1163
    Re: Vibration during acceleration
    Tom,
    Two possibilities come to mind immediately.
    If you have not already done so, check the U-joints. A U-joint that is in the process of failing can do this.
    Check spark plugs/wires for one that breaking down under load.
    Maybe others will have more ideas.
    Verle
    • Verle R.
      • March 1, 1989
      • 1163
      Tom,
      Verle
      • Gary C.
        Administrator
        • October 1, 1982
        • 17769
        Tim, where's the vibration? In the steering wheel, clutch pedal or do you feel it in the bottom of your seat? Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Gary C.
          Administrator
          • October 1, 1982
          • 17769
          NCRS Texas Chapter
          • John M.
            • January 1, 2000
            • 175
            I have had a number of corvettes that the front seat mounting bolt / bolts hit the exhaust pipe where they go through the floor, only on acceleration when the engine lifts?? ....Thanks John Meissinger
            • John M.
              • January 1, 2000
              • 175
              • Timothy B.
                • January 1, 2004
                • 438
                Thanks for the responses! The vibration isn't in the wheel or the clutch, more in the seat but it isn't a big shake but more subtle. Some people might just ignore it, but my feeling is that it wasn't there in the past.
                • Timothy B.
                  • January 1, 2004
                  • 438
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17769
                    Tim, as John points out that could be something hitting caused by engine torque. More likely, if the vibration's felt in the bottom of the seat it's in the driveline; i.e. u joints in driveshaft on half shafts or even rear wheel bearings. Remote possibility in the rearend. Good luck, Gary....
                    NCRS Texas Chapter
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17769
                      NCRS Texas Chapter
                      • Kevin M.
                        • November 1, 2000
                        • 1271
                        That's what I was thinking exhaust touching something or just the plain feel of the pipes rumbling.
                        Kevin
                        • Kevin M.
                          • November 1, 2000
                          • 1271
                          Kevin
                          • Timothy B.
                            • January 1, 2004
                            • 438
                            This is an interesting thought. I think I will investigate on Saturday the possibility of parts touching during acceleration. Thanks for the input.
                            • Timothy B.
                              • January 1, 2004
                              • 438
