Re: 62 horn rebuild - NCRS Discussion Boards
Re: 62 horn rebuild
  • Leo G.
    • August 31, 1987
    • 116
    Re: 62 horn rebuild
    Dave I don't have an answer to your question. I have one for you. Do you have horn rebuild kit and if so who did you purchase it from?
  • David K.
    • January 31, 1976
    • 592
    Re: 62 horn rebuild
    I got it from Zip Products.
    • David K.
      • January 31, 1976
      • 592
      Re: 62 horn rebuild
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11287
        Re: 62 horn rebuild
        Dave,
        I rebuilt my 59s' horns(351/352) about 8 years ago using a kit from Paragon. One of mine was internaly rusted as yours must be. However, my kit came with replacement metal diaphrams then. It was part# 461K. I used 1 of my 2 diaphrams. The diaphrams do not come with the stud, and you must transfer the old stud to the new diaphram by drilling it out, tapping a 1/4-28 threaded hole and using a screw to attach the old stud to the new diaphram.
        The new kits from Zip do not come with the diaphrams and Paragons 461K isn't available any longer. No explanation. I also have a new kit from Zip and assumes the diaphrams are ok, and only comes with gaskets and rivets. I too am looking for new diaphrams as I have 2 sets of 62 horns(441/442) I need to restore. Hopefully only 1 of the 4 needs the diaphram.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11287
          Re: 62 horn rebuild
          Dave,
          • David K.
            • January 31, 1976
            • 592
            Re: 62 horn rebuild
            Rich, My instructions are the same as yours except line 10 is omitted. Line 4 of the reassembly is what reads confusing to me. Yes, I am sure hopping I don't need a diaphragm or I can find a source who has them.
            • David K.
              • January 31, 1976
              • 592
              Re: 62 horn rebuild
              • Mike E.
                • February 28, 1975
                • 5132
                Re: 62 horn rebuild
                Go to a local all-makes, all-models swap meet. Look for a set (or individual) Delco horns of the same size and shape as your originals. (Passenger car horns tended to take on less water than Corvette horns) Shake them. If they're quiet, pay the $3-5 asking price. (Check the number of "coils" in the outer tube to make sure it is a high or low note and is what you're looking for.
                Disassemble. Use diaphragm. Reassemble. Save money.
                • Mike E.
                  • February 28, 1975
                  • 5132
                  Re: 62 horn rebuild
                  • Gary Schisler
                    Re: 62 horn rebuild
                    Another source for horns suitable for donating parts, and more fun too, is your local salvage yard. Find one that hangs on to their really old cars and you will have a wealth of donor parts. I found that I can find the correct shape and size and then I use a couple of pieces of wire and a battery to test them.
                    Gary
                    • Gary Schisler
                      Re: 62 horn rebuild
                      Gary
                      • Terry D.
                        • May 31, 1987
                        • 2689
                        Re: 62 horn rebuild
                        Gary
                        With the price of steal as high as it is there are very few of those type of yards left, none in my part of Ohio.
                        • Terry D.
                          • May 31, 1987
                          • 2689
                          Re: 62 horn rebuild
                          Gary
