64 Ball Joint Replacement - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    Hi all,
    I am restoring my upper and lower control arms and was wondering what everyone's opinions are regarding the ball joint replacements? The parts houses offer both a OEM style and a replacement style. One cost $75 and the other $25. Is there a real noticeable difference between both for the additional $50. Any help here is greatly appreciated.
    Craig Willetts
  • Mark #28455
    Re: 64 Ball Joint Replacement
    The replacement style ball joints are obviously different from original. In addition, the repro "OEM style" are close, but slightly different from original. The "real NOS" ones go for a lot more. I recently sold a pair of the NOS uppers for over $300 on e-bay.
    Mark
    • Mark #28455
      Mark
      • Eugene B.
        • May 31, 1988
        • 710
        Craig,
        You may thinks that what I did is silly, but I'll offer it for your consideration.
        When I restored the control arms on my '65, I drilled out the rivets in the upper ball joints. The ball joints were original and were not worn out. Folks say that the upper bj's do not wear out nearly as soon as the bottom ones.
        After the control arms were restored and painted, I took the arms with the original "hand cleaned" upper bj's to Bairs and had them re-rivet the originals into the control arms. I had no choice but to replace the lower bj's with ones that looked good from Bairs.
        Call me crazy, but I wanted the original captured boot joints back on the car.
        Good luck with your restoration project.
        Gene
        • Eugene B.
          • May 31, 1988
          • 710
          Craig,
          Gene
          • Alan Drake
            Caution, please do some searching on the subject before jumping ahead. One of the biggest problems you (&I) are facing is to make the rivets look the same. As noted the real ball joints installed on the production line are different from those available today. The closest you will get is to purchase some service joints from ebay and then solve the rivet problem. ($300/2 is a good estimate & the lowers are the one's which fail first and may be worth more $)
            Here is another idea, purchase the a arm sets complete with repro joints and save your originals and slowly restore them as parts and rivets become feasible.
            Not sure how many points cars are getting hit for with these sets, but it may not be enough to worry about.
            • Alan Drake
              • Alan Drake
                Rivet Correctness
                Gene was thinking to try the same thing for a future project. How was the result of the Bairs rivet work. Was is Exactly Correct ??
                • Alan Drake
                  Rivet Correctness
                  • Gary B.
                    • February 1, 1997
                    • 7080
                    Deduct for incorrect rivet squash?
                    Just a practical question. If one deducts 1 point for bolted vs. riveted upper balls joint, how much can one fairly deduct for a riveted ball joint where the rivet squash is not 100% correct?
                    Gary
                    • Eugene B.
                      • May 31, 1988
                      • 710
                      Re: Rivet Correctness
                      Alan,
                      Now that you mention it, Bairs rivet work is probably not identical to the factory. I'm not wise enough to know what "exactly correct" is. I have not had my car judged yet, so I don't have a feel for any possible deductions.
                      Gene
                      • Kent K.
                        • December 1, 1982
                        • 1139
                        When I restored my '67 back in 1993-4, I left the original uppers & lowers on. They're still there and work just fine.
                        Kent
                        Kent
                        NCM Founder - Member #718
                        • Rob M.
                          • June 30, 1999
                          • 171
                          I started a thread a couple weeks ago on this. Check out the link below for some comments and pictures.
                          Rob
                          https://www.ncrs.org/forum/tech.cgi/frames/read/321951
                          My Project Pictures
                          http://temp.corvetteforum.net/classics/l78vetteman/
