C2 BB Stumbles When Hot... - NCRS Discussion Boards
  • Glenn B.
    • March 1, 2005
    • 169
    Had some great weather this weekend, and a chance to let my stock 67 BB stretch its legs. It seems to have developed a little problem over the winter. When the car is hot, above normal operating temp (sitting iding in the sun), and you put it under hard load - it stutters and stumbles. Once the temp drops - it revs under load normally. Plugs are good, gas is fresh, air cleaner good, carb properly adjusted. I am suspecting the coil.
    Appreciate any troubleshooting suggestions from those with far more experience than I.
  • Mark E.
    • April 1, 1993
    • 4607
    Re: C2 BB Stumbles When Hot...
    Glenn,
    On behalf of NCRS, I apologize for taking over seven years to respond to your inquiry about your stumbling big block.
    Have you tried yanking it out and replacing it with an LS engine?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
