Common C3 A/C (1974) Problems? - NCRS Discussion Boards
  • Paul L.
    • November 1, 2002
    • 1414
    Re: Common C3 A/C (1974) Problems?
    Terry,
    GM dealers in Canada will do the R-134 conversion. No problem. They will not touch R-12 by law.
    • Paul L.
      • November 1, 2002
      • 1414
      Terry,
      • Verle R.
        • March 1, 1989
        • 1163
        #18
        I suspect you can get the job done at a small shop much cheaper than a GM dealer.
        Ask your local chapter members, go to a local cruise night and talk to people with muscle cars, street rods, etc. Try to get a consensus on a shop that does good work for a reasonable price.
        Verle
        • Verle R.
          • March 1, 1989
          • 1163
          #19
          Verle
          • Paul L.
            • November 1, 2002
            • 1414
            #20
            Verle,
            I have a number of things to do when the car arrives. Mostly trivial but I am anal on detail. And this car needs some interior trim items. Yes, a local shop is an option. Geesh, I've done a 1979, a 1967, and here we go again! As people say, there is no end to this madness.
            • Paul L.
              • November 1, 2002
              • 1414
              #21
              Verle,
              • Paul L.
                • November 1, 2002
                • 1414
                #22
                My 1967 is for sale in Canada.
                • Paul L.
                  • November 1, 2002
                  • 1414
                  #23
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    #24
                    That article is more or less correct- it's difficult or impossible to get R12 as a do it yourselfer in Canada. Nothing stops you from going to Canadian Tire to have them do it professionally however.
                    I had my old Infiniti (RIP) topped up at the corner garage before passing it on the next victim, ummm, owner.
                    • Michael W.
                      • April 1, 1997
                      • 4290
                      #25
                      • Bert L.
                        • April 30, 1977
                        • 428
                        #26
                        I don't think you will be able to have R-12 legally replenished in Canada.
                        Try this site; I've used their products and they work!
                        www.redtek.com
                        • Bert L.
                          • April 30, 1977
                          • 428
                          #27
                          www.redtek.com
                          • Rich Puleo
                            #28
                            You don't have to convert, & you don't have to use 12 as expensive as it is. Go with the synthetic R12 replacement. It works fine. freeze 12 is one, autofrost is a company that makes it. You use about a 20% less charge than the 12, & it works well with the frigidaire system. By the way, it is a very common problem that the front compressor seal seeps allowing the charge to deplete over a few months. It was common for GM to need up to a pound of freon in season. Most of the compressor seals leak over time, & you can spend $$$ to get it fixed, only to have it leak again. Also common with age are dried out o-rings. the only way to tell for sure is to hook up the gauges & take some pressure readings, then do a leak test if the loss is significant. You can look for caked up oil & road dirt around the fittings. That's usually a tell tale but not always the cause.
                            As a former dealer employee, stick to a resto shop in the area, go with a reccomendation. GM dealers are not equipped for R12 or retrofitting, & if one should take on the project it would be quite expensive.
                            • Rich Puleo
                              #29
                              • Paul L.
                                • November 1, 2002
                                • 1414
                                #30
                                Thank to All for the comments. Very much appreciated. Sounds as if this could get expensive but I'll check with Club members as to a shop that has both expertise and reasonable rates.
