hello,I haven't found the method of grounding heater fan motor I seem to recall a wire on housing mount screw but I can't seem to find it thanks, mike
heater fan ground 1960
Tags: None
- Top
Re: heater fan ground 1960
The other thing you have to watch out for is some people will put the foam gasket between the T-stat mounting plate and the fan housing instead of on the engine compartment sdie of the plate. If this is done, it will insulate the fan housing from the T-stat mounting plate, which is where the bowden cable terminates. I have fixed a couple of cars like this by inserting a Tek screw through the inside of the fan housing into the mounting plate. This screw is hidden inside the fan housing, and it is way easier than pulling the entire heater assembly back apart!
Regards, John McGraw- Top
