'54 horns - NCRS Discussion Boards
'54 horns
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12738
    '54 horns
    I seems my horns on my '54 are missing or otherwise I don't know where to look. Where should these babies being located?
    regards,
    Rob.
    Rob.
    NCRS Software Developer
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '54 horns
    same area as your other C1
    • Roy B.
      • February 1, 1975
      • 7044
      Re: '54 horns
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12738
        Re: '54 horns
        so left and right behind the grill?
        Rob.
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12738
          Re: '54 horns
          Rob.
          • Roy B.
            • February 1, 1975
            • 7044
            Re: '54 horns
            Yes upper area same as 53 to 57 all look alike and use the same bracket
            • Roy B.
              • February 1, 1975
              • 7044
              Re: '54 horns
              • Brett H.
                • January 1, 1996
                • 367
                Re: '54 horns
                If they are missing, you can use passenger car form 53 or 54. The part numbers are not judged and cannot be seen anyway.
                • Brett H.
                  • January 1, 1996
                  • 367
                  Re: '54 horns
                  • Brett H.
                    • January 1, 1996
                    • 367
                    Re: '54 horns
                    The horns are the same but the brackets have mounting holes 2' from center to center. Passenger car mounting holes are only 1.5" from denter to center of ea hole, if I remember correctly.
                    • Brett H.
                      • January 1, 1996
                      • 367
                      Re: '54 horns
                      • Roy B.
                        • February 1, 1975
                        • 7044
                        Re: '54 horns Brett you are right Brackets *NM*
                        • Roy B.
                          • February 1, 1975
                          • 7044
