C1 Turn Signal Switch - NCRS Discussion Boards
  • Dennis G.
    • February 28, 1993
    • 100
    I recently purchased what is supposed to be a NOS turn signal switch for an early Corvette. Gr 2.895, Part 5946173. The number on the switch in the black plastic is 5945073. Is that correct?
  • Roy B.
    • January 31, 1975
    • 7044
    Re: C1 Turn Signal Switch
    Numbers? But this is the correct end connectors if original , other wise it's the second design replacement ends having a slit causing them to fall out.
    What are your's?
    • Roy B.
      • January 31, 1975
      • 7044
      What are your's?
      • Dennis G.
        • February 28, 1993
        • 100
        These have the slits. By the way, nice job with the pictures and thanks for the response.
        • Dennis G.
          • February 28, 1993
          • 100
            • March 31, 1990
            Remember the physical switch might have a PN emboss that corresponds to the naked switch while the physical assy (switch + attached wires) may well have another PN...
              • March 31, 1990
