Correct Clutch Fork for '61? - NCRS Discussion Boards
  • Mike B.
    • November 1, 2004
    • 389
    Can someone (Joe?) provide the correct clutch fork part number for a '61 with an aluminum "553" bellhousing? I am getting ready to pull the works as one of the fingers of the fork spring broke. I want to be sure that it is the right fork before I bother to repair it.
    My understanding is that there may not be a part number stamped on the fork. If that is the case, are there unique identifiers or critical dimensions that I can check?
    Thank you,
    Mike
    • 43259
    Re: Correct Clutch Fork for '61?
    Mike-----
    I'm out-of-town and I don't recall the part number of the C1 clutch fork. However, I can tell you that there is no part number to be found on the piece and the C1 fork appears very similar to the 64-81 fork. But, it's not the same and is not interchangeable.
      • 43259
      Mike-----
      • Mike B.
        • November 1, 2004
        • 389
        Joe,
        Thanks for the reply. It seems like the only option to get the correct fork is to buy it from a Corvette supplier and hope that they got it right.
        I remain interested in the correct part number and can wait until you get back from out of town.
        Thanks again,
        Mike
        • Mike B.
          • November 1, 2004
          • 389
          Joe,
          Thanks again,
          Mike
