Tie rod orientation C1 - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    I have a 61 . I am rebuilding the front suspension. On the tie rod ends which thread orientation goes where. Does the right had thread end go inboard or outboard? Is it the same on both sides? Jerry
  • Mike M.
    • May 31, 1974
    • 8405
    Re: Tie rod orientation C1
    either way, it shouldn't matter from a function standpoint. mike.
    • Mike M.
      • May 31, 1974
      • 8405
        Jerry -
        Here's a preliminary Graphics sketch I found years ago for assembly of the midyear steering linkage components at Buffalo; it shows the LH threads on the inboard ends and the RH threads on the outboard ends. Don't know if they were done that way consistently or not. Just make sure both sides are done the same way.
        It was designed that way on purpose, so the steering wheel could be centered by turning both sleeves the same amount in the same direction without affecting the toe-in setting (shortened one side while lengthening the other side). Of course, on a C1, steering wheel centering is accomplished at the drag link, not at the tie rod sleeves.
          Jerry -
          • Jerry G.
            • April 1, 1985
            • 1022
            Re: Thanks guys, as always very insightful *NM*
            • Jerry G.
              • April 1, 1985
              • 1022
