1968 L36 Coupe with A/C and M20 - NCRS Discussion Boards
  • Charles F.
    • April 30, 2006
    • 99
    Hi:
    Need to find parts but don't have the part numbers. Would appreciate the part numbers and any leads on where to source the parts. Attempting to do a proper NCRS restoration:
    1. Windshield stainless steel molding (vertical piece)for the right side;
    2. Accelerator spring (the double ended spring that attaches to the pedal
    itself);
    3. The 8"-10" bolt that goes through the starter to the starter brace. It
    has a nipple thread on the end.
    Don't have access at the moment to either my AIM or the judging manual.
    Thanks.
    Chuck Faillace
    Re: 1968 L36 Coupe with A/C and M20
    Chuck -
    I get those starter through-bolts with the threads on the end from a local mom-and-pop starter/alternator rebuild shop.
      Chuck -
        • 43288
        Chuck------
        molding= GM #3912722----long since discontinued
        accelerator pedal spring= originally GM #3909982; now GM #368077
        starter through bolt with extension= last available as GM #1931654. This part is discontinued. There may or may not be a supercessive part number. I can't find one.
          • 43288
          Chuck------
          • Anthony S.
            • April 3, 2008
            • 183
            Here's a pedal spring:
            • Anthony S.
              • April 3, 2008
              • 183
