C2 Spare Tire bolt - From 67? - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2138
    I have seen two 1967 Corvettes with spare tire holder bolts that look like this one. Is it possible both cars had this part transferred from an early 63? This looks more "home-made" than the one on my 66. Two sides have a small plate welded in. One plate has a small round bumper or washer/spacer attached to it. (Sorry, no photo of the inside yet.)
    http://michiganncrs.homestead.com/IMG_7533.JPG
    http://michiganncrs.homestead.com/IMG_7537.JPG
    Two photos linked above. One taken without a flash. Both photos are of the same part.
    Tom Dingman
    4889
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Harry Sadlock
    Re: C2 Spare Tire bolt - From 67?
    I do believe that is a 63 only part.
    Harry
    • Harry Sadlock
      Harry
      • Tom D.
        • 2138
        Here's a photo of the inside. My description of the inside part of this should have said "folded over tab" instead of spacer or washer.
        Tom Dingman
        4889
        Michigan Chapter
        Tom Dingman
        • Tom D.
          • 2138
          Tom Dingman
          4889
          Michigan Chapter
          Tom Dingman
          • Rick A.
            • July 31, 2002
            • 2147
            agree with Harry
            Rick Aleshire
            2016 Ebony C7R Z06 "ROSA"
            • Rick A.
              • July 31, 2002
              • 2147
              agree with Harry
              Rick Aleshire
              • Peter L.
                • May 31, 1983
                • 1930
                Tom - I think Harry and Rick have it IDed correctly. In addition, I'm curious if in fact the piece is an original or a later piece because there is a roll pin at the end of the bolt rather than a solid tapered pin. My experience has been that the original C2 spare tire lock bolts and even the C3s had a solid tapered pin in them while the majority of the reproduction pieces I've seen have had the rolled pin. Pete
                • Peter L.
                  • May 31, 1983
                  • 1930
                  • Tom D.
                    • 2138
                    Thanks and See above *NM*
                    Michigan Chapter
                    Tom Dingman
                    • Tom D.
                      • 2138
                      Michigan Chapter
                      Tom Dingman
                      • Wayne M.
                        • March 1, 1980
                        • 6414
                        Solid pin (not split roll pin)
                        Tom, I believe that Pete L. was refering to the pin through the threaded part, not the barrel nut. On your first picture, it seems to be a hollow roll pin. Am not sure if this was original (early) '63 design or not. Later C2 years were solid.
                        • Wayne M.
                          • March 1, 1980
                          • 6414
                          • Harry Sadlock
                            Re: Solid pin (not split roll pin)
                            This is off my 63, I still need to plate one part. The pin is not shown, but it is solid, it is not rolled.
                            I also added the front hanger. It's the second design as I recall. Note the bottom is round.
                            Harry
                            • Harry Sadlock
                              Harry
