dash capacitor - NCRS Discussion Boards
dash capacitor
  • John S.
    • July 31, 1990
    • 292
    dash capacitor
    Where does the capacitor hook to on the small gauges on the 1956-1962. I beleive one end is to the fuel guage but not sure. thanks fo any help john
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: dash capacitor
    John...
    there is much discuss on this browm paper wrapped capacitor...the "black" band end of the capacitor is grounded to a stud on the the instrument panel. The capacitors other wire is attached to the ammeter "red" wire terminal on the passenger side. this wire can be attached to the "black" wire terminal on the drivers side and still funtion property. Do not forget that the AIM circuit wire illustration is backwards.
    • Dennis A.
      • April 30, 1999
      • 1010
      Re: dash capacitor
      John...
      • Jack H.
        • March 31, 1990
        • 9906
        FYI...
        The capacitor is non-polar, meaning it doesn't matter which end connects to what. The black line on one end simply marks the lead wire that connects to the OUTER storage plate in the cap.
        The through was IF the cap should wiggle/rub against adjacent metal surfaces and wear through the protective wax/paper wrap, which lead wire should make contact first...the one connected to ground or the one connected to B+. If the grounded side made first contact, no harm would result.
        BUT, that thinking is pretty shallow. If there's enough friction/wear to 'saw' through the cap's outer package, it's simply a matter of time before you wear through the outer plate + dielectric and make contact with the inner plate that's connected to the hot side of the circuit!
        • Jack H.
          • March 31, 1990
          • 9906
          FYI...
          • John S.
            • July 31, 1990
            • 292
            Re: FYI...
            Wow Guys what great info. This board has been great to share information. Again a BIG thank you. john
            • John S.
              • July 31, 1990
              • 292
              Re: FYI...
              • J O.
                • August 31, 1987
                • 19
                Re: dash capacitor
                Ditto.
                my 58 still has this original capacitor attached to the ammeter.
                • J O.
                  • August 31, 1987
                  • 19
                  Re: dash capacitor
                  Ditto.
