C3 Hub Cap Scapes - NCRS Discussion Boards
C3 Hub Cap Scapes
  • Jack Corso
    C3 Hub Cap Scapes
    Any suggestions on how to get the curb rash off of my PO1's? I'm in central NJ
  • Eric F.
    • June 30, 2003
    • 319
    Re: C3 Hub Cap Scapes
    Are you referring to the center caps or the trim rings? The two are comprised of different metals so the way to repair or restore varies. Post more details and you'll likely get more answers to your question.
    • Jack C.
      • September 30, 1992
      • 1090
      The optional Deluxe P01 Wheel Covers.
      Jack Corso
      1972 Elkhart Green LT-1 Coupe 43,200 miles
      Top Flight 1994, 2018 & 2021
      • Harmon C.
        • August 31, 1994
        • 3228
        I found some that were in beter shape on the flat center hubcaps and switched the parts to make a better set of PO-2's. That type hubcap usally sells for less.
        Lyle
        Lyle
        • Jack C.
          • 1090
          That did enter my mind. I found several metal polishing guys in NJ that will take care of them.
          Jack Corso
