OK me again 55-56 water pump trivia - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    .55 early 56 first design #911 original water pump had TWO holes for seal leak drain, later the #911 was redesigned and had ONE hole .This stuff only matters me ?? // but not the JM ??,
  • Brett H.
    • January 1, 1996
    • 367
    Re: OK me again 55-56 water pump trivia
    Great stuff Roy!
    Thanks for posting the other stuff for me!!!
    • Brett H.
      • January 1, 1996
      • 367
      Great stuff Roy!
      • Ted S.
        • January 1, 1998
        • 747
        Roy, It matters to me. I'm more after "how it came from the factory". To me that's the interesting part. Do you know when the pump shifted to one drain hole? Also is there a difference in the heater hose fitting NPT? Thanks for sharing, Ted
        • Ted S.
          • January 1, 1998
          • 747
          • Roy B.
            • February 1, 1975
            • 7044
            Re: OK TED
            In 1958 also design
            • Roy B.
              • February 1, 1975
              • 7044
              Re: OK TED
              In 1958 also design
              • Roy B.
                • February 1, 1975
                • 7044
                Re: For "Ted" only??
                {It matters to me. I'm more after "how it came from the factory". To me that's the interesting part.}= you said//
                You and I feel the same way but not to some people unless it's in the JM. I'm a nut about correct original design parts. It dont matter to most but even like this fuel filter here (each was dated) I like this stuff and my 55 HAS this filter. Call me crazy!! I dont know if my postings upset others, but people like you I like the most.
                • Roy B.
                  • February 1, 1975
                  • 7044
                  • Kevin M.
                    • November 1, 2000
                    • 1271
                    Roy,
                    There are more original guys here than you think, I dig the pics of parts and save them all. The bad part is that people keep swapping out originals for JM parts all the time to play the game.
                    1963 red pinch welts anyone?
                    Kevin
                    • Kevin M.
                      • November 1, 2000
                      • 1271
                      Roy,
                      Kevin
                      • Robert J.
                        • September 30, 2004
                        • 117
                        Hi Roy; Had to run out to look.....Can't feel how many holes for the one on the car. It say's GM 1 The extra on the shelf has one hole and a casting mark of GM 5. Can't find a date code.... PS...I've got a balancer for you to replace the one you sent me. Thanks Bob
                        • Robert J.
                          • 117
                          • Roy B.
                            • February 1, 1975
                            • 7044
                            No date code on a WP GM 1 or GM 5 means nothing just the cast number the part was made in. The balancer great send it out when ever no hurry. Thanks
                            • Roy B.
                              • February 1, 1975
                              • 7044
