C1 Power Top - NCRS Discussion Boards
C1 Power Top
  • Ted S.
    • January 1, 1998
    • 747
    C1 Power Top
    Does any know of a rebuilder for the C1 power top components? I need to get the control valves and the pump rebuilt at a minimum. Is there a way to test the control valves and pump? I tried connecting one of the control valves to a 12V source and it didn't click or anything. I got sparks when I touched it to the battery so it looks like the solenoid coils don't have a break in them. I haven't tried anything with the pump. The positive wire is frayed where it enters the pump motor. Thanks Ted
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 Power Top *NM*
    • Roy B.
      • February 1, 1975
      • 7044
        Re: C1 Power Top
        Ted -
        Convertible Top Specialists in Inverness, Florida, (352) 637-5505, can take care of you - they can supply a new pump/motor assembly or rebuild yours, they have new lift cylinders and hose sets, and can rebuild all the solenoid valves.
          Re: C1 Power Top
          Ted -
          • Ted S.
            • January 1, 1998
            • 747
            Re: C1 Power Top
            Roy, Thanks. Where can I get the rest of the article? Ted
            • Ted S.
              • January 1, 1998
              • 747
              Re: C1 Power Top
              • Roy B.
                • February 1, 1975
                • 7044
                Re: C1 Power Top
                Well some one did a great one in the restorer some time back on the PT ,see if you can find it!
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Re: C1 Power Top
