Re: C2 oil loss
John,
A high pressure pump is not a high volume pump, and vice versa.
The Melling 55 HV should NOT BE USED in any stock application.
The Melling 55 A should be used with the SHP engines
The Melling 55 should be used with low horse engines.
This, from the Melling website:
"Pressure is created by the resistance to flow. For example, the water flowing out of a garden hose has relative low pressure, but when you put your finger over the end of the hose, restricting that flow, the pressure within the hose increases and you see the result by increasing the distance the water travels as it leaves the hose. The resistance to oil flow Inside an engine is from the clearances of the bearing and lifter bore. Engines with increased clearances will require greater flow to maintain the same pressure. As the RPM of the engine increases more oil is required. The oil pump selected should be able to flow the volume of oil required to maintain the pressure desired. A relief spring within the pump relieves the pressure when it reaches the desired level. High pressure pumps have a higher pressure relief spring as also do most high volume pumps. The main disadvantage of using a pump with the ability to flow more than required by the engine resulting in this bypass opening is a very small loss of horsepower."
Joe
John,
Joe
