'62 Heat Shield Screws - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    The AIM shows the heat shields on a '62 are fastened to the engine block with a part number 193938 screw assembly. It's a 1/4" screw with a captive washer. I believe it's called an "assembly" because the part contains that washer.
    I'm trying to determine if this washer is flat, split, or toothed.
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: '62 Heat Shield Screws
    My memory says split. I'm sure others will correct if it's star.
    • Wayne P.
      • August 31, 1975
      • 1025
      • Timothy B.
        • April 30, 1983
        • 5194
        Chris,
        I went junk yarding to find these bolts and took them off a mid sixties chevy and they have a split washer. The four heat shields as well as the two spark plug wire brackets that bolt to the back of the engine block. I found all six bolts the same.
        • Timothy B.
          • April 30, 1983
          • 5194
          Chris,
