C2 '65 L75 Carb Install - NCRS Discussion Boards
    • August 31, 1999
    • 155
    I'm replacing the incorrect AFB (3721 SA) with the correct, and restored, 3721 SB carb. Old carb had lock washers on the mounting studs. Is this correct or no lock washers? Also, is there a specified torque value (in"/lbs.) for the hold-down nuts?
    Jack
  • Bryan L.
    • June 30, 1998
    • 397
    Re: C2 '65 L75 Carb Install
    I don't think there were originally any lock washers on the carb studs. The torque values I've always heard were around 144 inch lbs. or around 12 ft. lbs. but this is subject to correction.
    BL
    • Bryan L.
      • June 30, 1998
      • 397
      BL
        • August 31, 1999
        • 155
        Forgot to add that page 262 of Noland's book has 2 pix of the engine compartment of a base engine car, no lock washers visible.
          • August 31, 1999
          • 155
          • Mike M.
            • May 31, 1974
            • 8408
            certain there were no lock washers , just the four hex nuts. mike
            • Mike M.
              • May 31, 1974
              • 8408
              • John D.
                • December 1, 1979
                • 5507
                Jack, It appears that old GM didn't think much of lock washers. Musta slowed the line down. So many times in the mid years-especially the fuel cars no locks were used. That is typically spelled out in our manuals. Another rule of thumb that you can throw out the window is this. Aluminum no lock washers. Steel-lock washers. WRONG. I don't know who started that one years ago. Probably old DW. Check the aims also. JD
                • John D.
                  • December 1, 1979
                  • 5507
