carburettor power valve - NCRS Discussion Boards
  • Jack Steele
    I have a blown power valve in the primary side of my correct Holley carb. The documents that come with a carb parts kit states and supplies # 8 to 4.5 depending on the carb part number. My Holley book says to us a power valve 1.5 numbers less then the idle vacume which is 13.5 on my 396 engine. Even Napa only supplies 6 or 4.5 power valves. which is correct.
    TIA.
    Jack Steele
    1965 Corvette. 396 engine.
  • Michael B.
    • June 18, 2007
    • 400
    Re: carburettor power valve
    From the Holley website....
    QUESTION How do I tell what size power valve I need?
    ANSWER To properly size a power valve, take a vaccum reading at idle and if it is above 12" for a standard transmission a 6.5" will be safe to use. For automatic transmissions take a vaccume reading in gear at idle and if the vaccum is below 12" divide that in half for proper size. Example 9" of vaccume in gear at idle will require a 4.5" power valve.
    • Michael B.
      • June 18, 2007
      • 400
      • Ken A.
        • July 31, 1986
        • 929
        All big blocks use a 65 power valve. You should also install the anti bolw out kit while you're at it.
        • Ken A.
          • July 31, 1986
          • 929
            Jack -
            There's no listing in the '65 Shop Manual Supplement that details the LIST 3124 Holley on your engine due to its mid-season introduction, but the carburetor numerical listing chart at the Holley site shows the 3124 as originally using a #85 power valve.
            Holley Carb Numerical Listing
              Jack -
              • Jack Steele
                Thanks guys. I knew that someone would know.
                Thanks again
                Jack
