1111024 Distributor Identification - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 485
    Is there any way (other than the band which can be repro'd) to identify a 1111024 distributor? Application is for 1963 340HP.
    Thanks in Advance,
    Fred
    • 43289
    Thanks in Advance,
    Fred
    Fred-----
    There's no absolutely, positive way I know of. Two key signs, though, would be the installed vacuum control (should be 1116201 if original to the distributor) and the autocam brazed to the top of the mainshaft. There is a code stamped into the autocam but, unfortunately, I do not know what it is for the 1111024 distributor.
    One other thing to keep in mind: just about any tach drive distributor could be configured to be a duplicate of the original 1111024 if one has the correct components. With all of the correct components, it would be indistinguishable from an original 1111024.
    • Frederick H.
      • August 31, 1983
      • 485
      Thanks Joe - kinda what I figured after doing a little more digging.
      Fred
      • Timothy B.
        • April 30, 1983
        • 5203
        Fred, the weights should be stamped 37, the autocam should be stamped 54 and the vacuum advance should be stamped 201-15.
        I'm pretty sure the centrifugal advance specs are 0@700 24*@4600.
        • Frederick H.
          • August 31, 1983
          • 485
          Thanks Tim - will have the current seller confirm.
