1966 Removable Hardtop Installation (Need Help/Advice) - NCRS Discussion Boards
  • Larry E.
    • 1698
    Hello: Need help with the above. Have 66 Convertible and want to install my removable
    hardtop which has not been on in years. Hardtop is now in a "Made for Holder" in my
    basement (Heated) and Protected with cover. Now:
    Can someone with experience and knowledge give me "Step by Step" instructions on
    how to install while protecting the paint. (Rally Red) Will have my friend helping me so
    two of us will try to do this. This last thing I want to do is damage the paint. Need all the
    details. Thanks in Advance>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Brian M.
    • February 1, 1997
    • 1842
    I've seen the paint protection strip used for the hard top protection but it looks hokey. I'd have the whole panel covered in PPF. JMHO Good Luck, they look so Good with the top on.
    • Leif A.
      • August 31, 1997
      • 3654
      I'll second Brian's suggestion of using PPF on the entire panel.
      Leif
      • Larry E.
        • 1698
        Brian: Thanks for the comments. I think the Removable Top does look good from the
        Side; not the back. I do not like the "slope of the glass"; the C3 Top looks a lot better
        then the C2's. Of course JMHO>Still want to try to put it on; something different for sure.
        Larry P.S. Need more comments and thanks
        Larry
        • Larry E.
          • 1698
          Upon doing some research it looks to me the correct way is to start from the back then
          to the side then the last step is to "latch" the front. Question: Can one lay down the top on
          the back of the car with out the back bolts attached? That way there would be less chance of getting
          the paint damaged? Then: After the side and front are secured (Loosely) then attach the
          back bolts to the top to drop in the holes? Also thinking not even using the back bolts since I
          am the proud owner of a "trailer queen" and not used at all on the streets. This way the
          seal on the back would not be "pinched down" thus less chance of marking the paint.
          Thoughts on my idea's??? Thanks>Larry P.S. I hope I am explaining this correctly.
          Larry
          • Patrick B.
            • August 31, 1985
            • 2012
            Larry- You can't put the rear bolts in last, but can certainly attach the top without the rear bolts. It takes at least two people. Position the front prongs into the windshield frame holes, and lower the rear of the top. This will position the side mounts next to the threaded holes in the top hatch. It might be a tight fit so be careful not the scratch the paint on the top hatch. Put the side bolts in hand tight, then latch the front latches. You may need someone to push the front of the top down while you latch it.
            • Kent S.
              • February 1, 1993
              • 209
              I'd be concerned about the hardtop shifting around with no back bolts - even in a trailer.
              • Joe V.
                Infrequent User
                • December 15, 2010
                • 7
                Here is what I have done to try to prevent any paint chips. I covered the side mounts with heat shrink tubing. I installed the two carriage bolts on the top, I put a dab of RTV on the carriage bolt heads to keep them in place. Then I put a rubber washer on the bolt with another dab of RTV to keep the rubber washer in place. To prevent any deck lid damage I placed rubber protectors on the threaded screw. When, with a helper, I go to install the top I put a couple of towels on the deck lid for added protection moving them as we are aligning the carriage bolts to the holes. Additionally I cover the convertible top with a towel so if I drop a nut or washer they don't get lost in the folds of the convertible top.
                You do not have permission to view this gallery.
                This gallery has 3 photos.
                • Larry E.
                  • 1698
                  Joe: Looks like you covered a lot problems before they start. Question: Has your Window
                  Rubber seal "marked" your paint? Do you use that film that was talked about at the start
                  of this thread? Any thoughts that can prevent this? Thanks Larry P.S. Thinking I will not
                  use the carriage bolts for this reason since car is a "trailer queen".
                  Larry
