Parking brake warning light '65 - NCRS Discussion Boards
  • Twan B.
    • June 30, 2005
    • 211
    Hi.
    When I pull my parkingbrake handle on my '65 conv. 327/300 the alarm light on my instrumentpanel don't light up "in the past it worked wel".
    The tan ground cable on the end of the parkingbrake is oke and also the light bulb.
    Can someone tell me were the 12v for the lightbulb comming from?
    All harness are new.
  • Mark M.
    • October 21, 2008
    • 343
    Is the small L shape switch that the tan wire plugs into working OK ?
    • Twan B.
      • June 30, 2005
      • 211
      Mark,
      I"ll believe the tan wire is the ground. The wire on the bulb don't get the 12v.
      It looks like there is some switch.
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 930
        The bulb gets 12 volts through the pink wire that powers all the gauges. The bulb should be in the black plastic bulb holder with the pink & tan wires.
        • Twan B.
          • June 30, 2005
          • 211
          Problem is solved, thanks for the help.
          • Joseph S.
            • March 1, 1985
            • 930
            Great, but please tell us what you found. It's always great to hear what the actual issue was.
