idler pulley - NCRS Discussion Boards
idler pulley
  • Howard H.
    • January 10, 2007
    • 142
    idler pulley
    On page 151 of the new 63-64 technical Information and Judging Guide it states that all engines except the L76 air conditioned models use an idler assembly. So, if the car has power steering it will need the ad on pulley on the crank? This is for a 64 L-75 engine.
  • Howard H.
    • January 10, 2007
    • 142
    I meant to question if the idler pulley statement is correct in the judging guide. I thought only the high horse engines used the idler pulley.
    Howard Hiller
    • Peter H.
      • April 1, 1980
      • 230
      Howard. The 7th Edition Paragraph Heading says 1963 + 1964 L76 + L84 Engines Only. Yes That First Line Is Confusing. I Believe The 8th Edition Corrected That
      Peter 🇨🇦
      • Mark F.
        • July 31, 1998
        • 1591
        Originally posted by Howard Hiller (46797)
        I meant to question if the idler pulley statement is correct in the judging guide. I thought only the high horse engines used the idler pulley. Howard Hiller
        Joe Lucia is your guy for the answer...
        thx,
        Mark
          • 43273
          Howard------
          For 1963-64 the L-76 and L-84 were the only engines equipped with an idler pulley. It was an assembly of GM #3829191.
          • Howard H.
            • January 10, 2007
            • 142
            Thanks Joe and everyone for your responses. I have the eighth edition and this is what it states unless I am reading it wrong.
            Howard
            • Dorsey F.
              • April 11, 2022
              • 35
              Joe has it correct, except add the AC equipped did not.
