Heater Motor Resistor - NCRS Discussion Boards
  • Ed S.
    • August 6, 2014
    • 1390
    Got my heater box / core out for a refresh (64 non AC car). Looking an my (original) motor resistor. It works as designed - but it is 61 years old. This is a great opportunity to replace it. Repro's are not expensive - should I replace it? Are repros any good? Or, should I stick with the original. I understand you can get to it by removing just the glove box. What do you recommend?
    Thanks for the advice.
    You do not have permission to view this gallery.
    This gallery has 3 photos.
    Ed
  • John W.
    • December 15, 2015
    • 64
    Ed,
    I refurbished my 64 (non-ac) heater box and just went ahead and replaced the heater resistor for all the reasons you stated. It’s 61 years old and repro’s are inexpensive. I saved my working original, so if the repro craps out, I will reinstall the original. I just didn’t want to deal with the heater box again in this lifetime.
    John
    • Edward J.
      • September 15, 2008
      • 6957
      Ed, I myself have not seen a non a A/C resistor fail, a simple inspection while it out will show excessive heat , when it fails the coils will melt and open. What I would do is look at the electrical connectors they tend to heat up causing an open in that circuit. My take is it’s has lasted 60+ years and with repro parts? Myself I have never used my heater in 17 years of ownership, only during operations check during flight judging.
      • Ed S.
        • August 6, 2014
        • 1390
        Thanks for the response - I examined the coiled wires on mine carefully - it is uniformly greyish from light surface corrosion but there are no burned or obvious hot spots. I intend to reinstall it. Those resistors may be one of the few parts on C2s that were over-engineered and designed to sustain a direct lightening strike.
        Ed
