Regarding gaskets and seals for the intake manifold on a 67 big block, the current judging guide (page 118) reads "Big block engines use a small rounded tab with a small raised GM ID which may only be visible at the rear." In 2025 can I still find a set of gaskets and seals with this "correct" appearance? If yes, where? Thanks in advance.
Yes, I know the image below is for a small block.
