Recently, I had an issue with the alignment of 1-2 gears on my Muncie 4-speed with a great deal of difficulty getting the trans into first gear. I have a 327-350hp motor and the factory Muncie/shifter. Following the usual procedure, I placed the gear shifter in neutral and was able to disconnect the 3 shifter rods on the driver's side of the transmission. I inserted the alignment tool at the base of the shifter and got all three rods to line up and lock in place. I set lever 1-2 and lever 3-4 levers on the transmission to neutral. The reverse lever was left as it was (as I believe it is either in gear or it isn't, if you follow me). All three rods then lined up and I was able to adjust the ends of the rods to lock them in place. Now, all forward gears work smoothly when I shift the car as usual. (I didn't drive the car, I simply ran through the gears without the car running).
However, now I am locked out of reverse. The T-handle goes up and the shifter goes left but will not go over to reverse any longer. Any suggestions on what I did wrong? I retraced my steps and readjusted the reverse rod, but it still will not let me go into reverse. Appreciate any thoughts?
Thanks everyone....
Thanks everyone....
